quick dsmlink timing question
95ttalontsi
87
Aug 16, 2011
gerry, New York
I've done some searching and cant fiqure out when you are datalogging on dsmlink does it factor in the 5 degree base timing or do u have to add 5 to whatever dsmlink is telling u in the timing log. Just wondering cause i had an concern that my timing dropped to 2.9 degrees when i first hit the throttle to do a WOT 3rd gear pull and at the top of rpm range it climbed to about 15 degrees. some pulls it shows 1.8 * knock at 4500 some it dont. checked boostleaks, fully tuned up, plugs, wires. boost at 16PSI
mods
fic 850
evo 3 16g
aeromotive apr
apexi exhaust (silencer was in, dont know if the backpressure will cause any knock)
apexi downpipe
2g mani exh
ported 2g 02 housing
6 bolt engine with 2g pistons 1g head and 1990 CAS
act 2600
fidanza flywheel
K&N
dsmlink v2
arp headstuds
cometic HG
95 talon tsi awd
thanks
Follow the instuctions in the manual. Ground the diag port by the battery, use a timing light at idle to verify that its 5 degrees btdc. I have tried to use dsmlink solely to verify base timing, never had luck... just break out the timing light, and a 12mm wrench to adjust the Cam Angle Sensor. Happy new year all! Pm me with any questions, i love to help!
I think I posted this log right. My timing is very low at low rpms, like 2 or 3 degrees and still some knock. 93 octane fuel. I can post more logs if needed, just let me know what u need to help me out. thanks, mike
I timed it using the camshaft marks and an adjustable timing light set to 5* grounding the timing conector manually, "not through dsmlink"
Here is a log that has large knock counts, I was goin up a small hill.
