Questions about turbo oil feed line kits from Extremepsi
Dylan0123
197
6
Dec 1, 2010
a, Illinois
I'm looking for an oil feed line for my evo 3 16g. I'd like a stainless line because I think it looks a little better than an oem 1g oil feed line, and I'm not sure if the 1g line would be a direct fit on my car.
#1: EXTREME PSI : Your #1 Source for In Stock Performance Parts
#2: EXTREME PSI : Your #1 Source for In Stock Performance Parts
Does the restrictor fitting in #2 work as well as the oem 1g banjo fitting?
Is it ok for the oil to just shoot straight into the inlet like in the #2 kit, or is it better to have a banjo fitting like in #1?
Is the banjo fitting in #1 the same as an oem banjo fitting that has the restrictor built in?
Is there a vendor that sells black stainless oil feed lines?
