Turbo Oil Feed Line from N/A OFH???
wrx110487
Mar 14, 2005
Cleveland, Ohio
I have a HX40 that I'm installing in my 4g swapped Eagle Summit that I'm planning to run with a restrictor off the oil filter housing. While going to install an oil pressure gauge and finding I have no pressure sender on my oil filter housing, I did some searching and discovered I have a N/A OFH. I was wondering if this will have any effect from feeding a turbo off this housing compared to a turbo one? Also what should I do for the oil pressure sender? Can I just mount it off the extra bottom allen bolt location? Here's some pictures as well. Thanks for any and all info, Chris
Yes mounting the oil feed line is perfectly fine on that one. I would run the oil feed line from the alan bolt, since a pressure sender threads are too small for it. I would eliminate the factory sender that's on there now in your pictures, and thread in your aftermarket one there.
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
