2G Oil feed line from 6 bolt OFH?
Kean tremblay
Mar 29, 2023
Gagetown, NB, Canada
I’m wondering what bolt do I tap into for an oil feed from the oil filter housing
6 bolt motor
Thank you
Since it's not plugged in anyways you could just remove the oil pressure switch from the front of the OFH or make a "T" off of that port if you plan to plug it back in. You could also remove either of the allen bolts in the front if they will come out. I believe the bottom one is pre-filter, and the top is post-filter.
This is the largest post-filter port available and is the one used originally by the 2G turbo models.
The "filtered" oil always comes from the "angled" port, not the straight port that has an allen plug in it. It's an easy way to remember. If you try to remove it, I would use a little bit of heat or you run the chance of stripping out the allen head.
We would normally use a fitting like this to thread into the OFH.
