question about tools
rgholmes08
Mar 26, 2011
Jenison, Michigan
I plan on picking up a 1g gsx around my area soon and I am getting it for very cheap but its gonna need some fixing up. Was just wondering what tools i need to pretty much take apart this car. I was wondering if anyone knew of a good set or had any suggestions on what tools i should get if I plan on fixing the car up and modding eventually.
the car is pretty much all 10mm, 12mm and 14mm bolts. someone correct me if im wrong but when i installed a new smic all i needed was a philips head and a 10mm.
10, 12, 14, 17 and 19mm sockets and wrenches is pretty much everything you will need. Other than a 32mm for the axle nut. Those and a couple screwdrivers and some pliers is the basic stuff you would need.
10mm, 12mm, 14mm, 17mm, 19mm, 36mm socket with the appropriate drive
All of those in standard sockets, deep sockets, and gear wrenches.
Regular and stubby phillips and flathead.
Hammer
Slipjoint regular pliers and needle nose pliers
Spare bolts and fuses and wire connectors.
Spare qt of oil.
Spare coolant.
Better get about 5 extra 12 & 14mm sockets. My car must eat them. Can never find one in the tool box.
From the great zimmer
-Dead blow hammer
-3/8" Cordless Impact (Makita or Dewalt make decent ones at a fair price)
-Pick tools (hook, straight, angle, 90-degree, etc)
-Pickup magnet with telescoping shaft. A LED pickup magnet is nice to have as well.
-Quality GearWrenches (8mm-19mm)
-22mm, 24mm, 27mm crescent wrenches and 1/2" sockets
-3/8" and 1/2" Impact universal joints (wobble joints, ~30-45 degrees of movement each way)
-Pry bar set
-Metric Tap and Die set. At a minimum have M6x1.0, M8x1.25, M10x1.25, M12x1.25, and pick up a M14x1.5.
-Adjustable crescent wrenches, three sizes.
-Good pair of utility scissors (Fiskars brand, serrated edge works best)
-Good side-cutters, and linesman pliers/sidecutters.
-Large Channel-Lock pliers
-Multi-Meter
-Boost Leak Tester for your application
-Hex Keys (Metric and SAE)
-Oil filter removal wrench (compression-band style works best)
-7/8" O2 sensor socket, or crow-foot socket
-Good breaker bar, and 5-foot extension pipe
-Quality 1/2" Impact gun (I like Ingersol Rand)
-Axle nut socket
-Clutch alignment tool (7/8" 20-spline / "Ford 20-spline")
-1/2" Quality Ratcheting Torque Wrench
-11mm 3/8" deep socket and 11mm gearwrench for T-bolt clamps.
-Metric 12-point deep-socket 1/2"-drive for your application -- to properly torque ARP fasteners using torque wrench with no extensions or adaptors.
-8mm, 10mm, 12mm, 14mm nut-drivers
-Loctite Red
-Gear oil syphon/pump (transfer pump)
-PB Blaster
-Anti-Seize
-Synthetic Grease
-Permatex Ultra Gray and Ultra Black RTV Silicone Sealant
-Several utility knives with extra razor blades
-Accurate air pressure gauge
-Metric brake line wrenches (cheap ones work fine since they are rarely used)
-Bench grinder or angle grinder will always be a helpful tool to own
These are my suggestions to add to the list.
Enjoy.
Get a timing tool kit from one of the vendors makes the job alot easier. A bake caliper compressor tool for the rear calipers. Also a pocketlogger setup.
Sent from my SAMSUNG-SGH-I897 using Tapatalk
Add a compression tester? A good one that can also connect to a compressor for leak testing and valve work.
Spark plug gap tool.
On the multi meter a digital one works for most tests. An analog one is needed for some special tests like reading the ODB codes with out a code reader.
Get a copy of a service manual, either a factory one or an aftermarket.
A hand vacuum pump. Make your own or get break bleed setup to use with the vacuum pump.
Digital camera to take pictures before you take things apart.
To mark things and hold them together while apart: Blue Masking tape, marker, ziplock or similar bags, plastic ties. Mechanics wire
Pop rivet and threaded insert tool.
Anyone have a recommendation for a good book or link for interpreting the data recorded by the palm and other data loggers?
Get a complete tool set from harbor freight. They have lifetime warranty now, just like craftsman
Yeah but unless you have a harbor freight store, you will have to mail it back and it will take a few weeks for replacements.
Plus, craftsmen lazer cut sockets are about the closest fitting socket I have ever used other than snapon. I would say the Lowe's brand (Kobalt) is good too. Very durable, nearly as good build quality as craftsmen. But, lowe's will not switch out broken ones in store, you need to mail them off too.
My most used tools :
10mm, 12mm, 14mm, 17mm, 19mm, You will want sockets and wrenchs for these sizes
15/16th or 25mm (Tranny Drain plug). Wrench
32mm Socket/Wrench for axle nuts
Slip Joint, and Needle Nose Pliers
Prybar
Screw Drivers
Timing Belt Tool set.
3-4 Foot section of steel pipe that will fit over your biggest ratchet
1-1.5 foot section of steel pipe
Brass Hammer, Rubber Mallet.
Compression Tester Boost Leak tester
Spark Plug Gap Tool
I use my jack handle for the above. It splits into 2 sections. I actually cut the end off it because I had no need for a 4 foot jack handle.
I used a 720 dollar 28 piece cornwell set and will never use another companies tools again!
Make a Boost leak tester and use it!
Ratcheting wrenches are sooo nice to have. :hellyeah:
I can fit just about all the necessary tools that I need in a small (12X6X6in) tool box (cept a breaker bar). I used to carry it with me in the car. It has saved my A** quite a few times. ;)
A couple more handy tools to have are boost leak tester, compression tester, leak down tester, repair manual, and a volt meter or dvom. A lot of people here will ask if you have done a comp test, boost leak test, or leak down. Really handy stuff to have
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
