Question about leaking to boost gauge
TxTspyder
May 22, 2004
Katy, Texas
I did my boost gauge install but the vaccum hose I used is one size too big to fit snuggly onto the fitting at the back of the boost gauge. Now I was going to use some kind of sealant and clamp later when I have time for the permenant install.
In the meantime I was wondering what effect on my car that a leak in tube that I tapped into would have. I tapped into the tube coming out of the passengers side of the fpr? solenoid like all the vfaqs said. When sitting in the car at idle, the hissing from the tube to my boost gauge is quite audible so there is definitely some outside air being sucked in and probably blown out under boost. I have a tight schedule the next week and would like know if this is hurting anything performance-wise until I get this sealed up.
Thanks for the help.
It'll run lean under vacuum and rich under boost, because the air isn't being metered correctly.
How much depends on how much is leaking. I'd be much more worried about the lean/vacuum part.
Why not just plug the line for now?!?
