Quarter Master twin disc users alignment?
hks-gst
171
Nov 8, 2004
Long Island, New York
Ok, I'm having alittle bit of a problem aligning my clutch to my flywheel on my Quarter Master twin disc setup. The hole in the center of the flywheel is a bit bigger then the input shaft hole on the clutch disc's so when I put in the plastic ACT alignment tool in to align it, the disc aren't perfectly centered on to the flywheel because the alignment tool has sag due to the bigger hole on the center of the flywheel. I'm alittle lost any input would be great. Thanks. :confused:
Just put some electrical tape on the end so it will fit snug in the hole... But honestly, I just kind of eyeballed it, mine sagged down too, but I just pushed it up a bit to center it, you can tell just by looking.
