1G Quarter Master twin disk flywheel resurface spec?
Here is a post from another thread, hopefully it helps.
Here is the same information I stated in your post on DSMTalk.com:
Well, for actual labor to rebuild the clutch itself, it is a pretty straight-forward process.
The wear specs for your Quarter Master 7.25" V-Drive Rally twin-disk are as follows:
Torque Spec for clutch cover fasteners: 22-24 ft/lbs.
Torque Spec for flywheel bolts: 100 ft/lbs w/ Loctite Red.
Wear Spec for floater plate: Minimum thickness of 0.175".
Warpage spec for floater plate: 0.006" max warpage.
Wear Spec for pressure plate: Minimum thickness of 0.598".
Warpage spec for pressure plate: 0.006" max warpage.
Wear Spec for friction disks: Minimum thickness of 0.230".
Initial thickness: 0.250" per friction disk.
**Check the clutch disk hubs for spline wear and replace if there is any wear or damage to the splines**
Wear Spec for the flywheel friction surface: Minimum step height of 0.095".
Initial step height is 0.110".
Clutch cover wear spec: check the clutch cover spring backing plate for uneven wear as well as the spring front for excessive wear along the friction surface with the throwout bearing.
Clutch fork wear: Check the wear tabs where the throwout bearing rides on it, and the pivot ball retainer spring for tightness and flatness. It should be flat against the clutch fork.
If you are still running the standard hub clutch disks, I would recommend upgrading to the Gear-Drive hub clutch disks as they will greatly improve decelleration chatter, smoother clutch engagement and dramatically improve engagement on the input shaft splines as it is a single hub on the input shaft instead of two floating disks on the input shaft splines.
As for all the replacement parts, I do have them on my website as well at:
http://www.tmzperformance.com/Mitsub...h Parts.html
Further information regarding the Gear-Drive clutch disks are on that page as well.
As for labor duration for removing the transmission and reinstalling it, most shops will bill 4-8 hours, and another 1 hour for clutch rebuild.
If you have any further questions regarding the products I would be happy to answer them for you!
Thanks,
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
  • For sale 2g 1997 Mitsubishi Motors Eclipse Service Manuals
    1997 Mitsubishi Motors Service Manuals $50 for the pair + shipping & paypal fees* I priced...
