Anfurnyy
Supporting Member
- 1,492
- 1,910
- Jul 4, 2020
Rapid City,
South Dakota
Looking for some insight on what might be going on with my QM twin disk.
I'll start by saying that it seems to release just fine with nothing weird happening or issues so to speak but when I pulled the clutch to replace rear main seal I saw an odd wear pattern between the disks and floaters.
Just for transparency sake, I bought the clutch used. the disks are NEW with probably 500-600 miles on them. Street driving only. I did not replace the floaters or pressure plate when I replaced the disks.
As you can see from the pictures below, some of the disks / floaters have wear on the outside, and then the other set has wear on the inside.
Looking for some ideas on what this might be, why it might be happening and if it's an issue or will be an issue?
Pictures SHOULD be in order of flywheel -> clutch cover with pictures of each side of the disks and floaters.
