Putting a 6 bolt block in my 2g 99 gst
Purplegstslut
Jun 30, 2016
Bristol, Wisconsin
Hey guys,
My 7 bolt needs a whole new rotating assembly due to a spun bearing. Looking to put an engine in temporarily while I build my 7 bolt block. Found a 6 bolt long block. Was in an automatic and mines a 5 speed. Wanted to use my 2g head on the 6 bolt block. Was looking to get some information on what I need to do to swap this 6 bolt in? I know I need a different flywheel and clutch. Do I need to change the wiring harness at all? Curious what all is needed to do the swap.
Hey guys,
https://www.roadraceengineering.com/2g6boltmotorinstall.htm
Magnus swap guide
Take a read through these first and see where you are still stuck.
