2G Cam sensor fault on my 6 bolt swap 97 gst
Nafierro
Apr 11, 2021
Utah
So I bought this wire set for my 6bolt swapped 97 because I was finding that most people recommended it but I’m getting a crankshaft position sensor code and a rough idle but when I plug the original wire to the crank shaft sensor it idles better but won’t really move much and throws a camshaft sensor code can anyone help on what to do?
looks to me like the black and yellow wires on the crank sensor plug need to be switched.
Good eye you have DUSTYBONER.
O The pic angle makes it hard to be sure if the wiring is backwards, check/confirm the blue wire of the connector matches the yellow wire of the other side of the connector,
If it doesn’t match then that’s your problem as Dustybonner mention.
Just to have it clear, this is not a 6 bolt block right?, the 6 bolt doesn’t has the CPS provision.
Thank You ! I’m going to switch them tomorrow after work
