Punishment Racing FMIC kit 2gA install pics?
thewraith
395
Aug 28, 2007
Washington,
Does anyone have pictures of the PR FMIC kit on a 2ga eclipse/talon. I'm curious as to where the bar that holds the fmic bolts onto? It looks like it is on the fog light/bumper support right below the headlights but there is no hole drilled there. The pictures that pr provided me do have the holes drilled or so it seems. I just need a picture of where the fmic bar is mounted and how the fmic is mounted on that ar.
THANK YOU! So you just drilled the black pieces that you mounted it on under each headlight??
You don't need to drill any holes, those brackets already have holes in them that the black crash bar mounts to.
If you haven't already done so, you need to remove those two brackets from your front bumper; a good reference is this awesome write-up AzDave did: 2G Bumper Removal 98 Eclipse RS.. you can clearly see the brackets in the pics towards the end of the write up.
You'll either need to toss out the black crash bar completely or cut the crap out of it to get it to fit with the FMIC and mounting bar. I (and many others) opted to remove it completely.
good luck :thumb:
Thanks again! I will take pictures once completed. My 2gb did have holes in those brackets- I didn't see the holes looking at my 2ga the other day. But I will double check.
And where is a good place to put the GM MAF with this kit? I just bought this kit and was wondering where other people placed it. And when installing this kit on a N/T TB, will I need to put a pipe in after the 45* bend from the TB and connect it to the pipe with the BOV flange on it?
Check out my YouTube vids under name jjrock5
I show you how to keep the crash beam with this exact FMIC and where the GM MAF goes. Comment, Rate, and subscribe! LOL
On this install were you running stock turbo? Becuase looks like you have the 16g Pipe route. I'm running a FPT-28 and I got t-28 pipe style with my PRFMIC and I'm having trouble putting everything together. everything is off by like 2"
Off how? Too low, too high? Right/left?
