pulling motor
EclipticalGS
1,449
19
Aug 25, 2008
walker, Michigan
Just a quick question on which is the easiest way to pull my 7-bolt for a new 7-bolt swap. Should i A. pull without tranny or pull with tranny. If i do pull with tranny how do i undo the cv joints that go into the tranny, and will i have to rebleed and redo the clutch master bleeding?
Or can i jsut unbolt the tranny from the block, drop the tranny mount slightly with a floor jack and a piece of wood, then tilt the motor and seperate it from tranny and input shaft, then pull it out?
Do i still have to disconect axles and rebleed clutch for both way? thanks
I believe you will have to bleed the clutch system when you put it all back together.
As for dropping the motor, i would pull out the motor from up top alltogether with the tranny.
Of course, don't forget to take the axles off first. Not sure how to do this as i have no experience with this, but i believe it comes off with pressure ?
Put the front of the car on jackstands. Take off the wheels. Remove the nuts on the end of the axles. Un hook the upper balljoint and tie rods. The axles can come out of the hub now, unless you are awd then there are 2 bolts that must come out of the block for the driver side. The clutch will not need bled if you just un bolt the slave from the trans and move it out of the way without disconnecting any of the lines to it. It is way easier to pull the engine and trans together.
I always pull the engine and tranny together. It makes a cleaner job and you can check your tranny for problems. Your axles pop out w/a pry bar between the tranny and the cv joint. You should get an engine leveler to help remove/reinstall engine it will tilt your engine. Lower the engine first and tilt to remove. You cant just pull straight up it is to wide. You will get on shock towers.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
