PTE GT30R/3076r: Feedback
pickens
544
5
Jan 17, 2003
Southern California, California
Who is running the PTE 3076r (GT30r) w/ the .48 a/r turbine housing. What are the spool, airflow, and 1/4 times that have been done.
Are these actual unmolested Garret CHRAs, or are they modified by PTE? I heard that they were not actual Garret cartdriges but a PTE version.
I have never head this, I doubt PTE would be pulling apart a GT center section to do modifications. I've always heard they just install their own turbine housing & thats it. The results of that turbo will be similar to the FP3052 or T3 3076, just abit less power potential but abit quicker spool. Probably looking in the 3600-4000 range for around 20 psi, but this can vary from setup to setup.
For track times are you looking for awd or fwd (as there's a huge difference, well atleast on street tires). On an awd or fwd with slicks you shouldn't have to much troubles running 12's & even some high 11's. I currently trap 113 on my 3052 with pump & meth but thats on street tries so first 2 gears are useless. Should pick up a few more mph, no problem, with some traction.
