PTE Fuel injector pintle caps?
are you talking about the black plastic that goes on the tip of the nozzle?... when i was putting the fuel rail back together i ended up squishing one of the plastics, the only solution i found was to call PTE and ask them for another set
Call PTE. They will come with the o-rings and seals also. I believe they were $15 about a month ago.
i felt the need to dig this up after googling. you can buy pintle caps at napa that fit. 6 bucks a set. they have to be dremeled down to the correct length, but hell, so do the stock pte pintle caps. i learned the hard way. i should have cut those pintles down to begin with and i never would have had a leak. theyre too long so the rail crushes and tears apart the upper o-rings. atleast on a 2g it does. also, use stock size upper o-rings, the green ones that came with mine were too big O.D.
