1G PTE 880 Injectors in 1g 91-94 Fuel Rail
RLSchwabe
126
30
Mar 21, 2014
Colorado Springs, Colorado
I currently have PTE 880cc injectors fitted in an AEM fuel rail:
I've been dealing with what I think are boost leak issues related to the injectors/fuel rail. So to be a bit safer (the o-rings on the AEM fuel rail don't seal all the time) I'm replacing the rail and the seals for the injectors. My question is what are all the appropriate seals/seats I need to use when I'm running the PTE 880 cc injectors on an OEM 91-94 1G fuel rail? I've ordered these seals:
And these injector sheets (FUEL INJECTOR SEAT CUSHION (FUEL INJECTOR SHEET) REPLACEMENT SET (4):
Should I be installing the injector sheets also? Or are they not supposed to be installed with my injectors? Anything I'm missing?
Thank you.
