pte 4431e 60 trim install problem
dsmfreak21
Nov 20, 2002
Orland Park,
So im trying to mount my turbo, but the problem is that the little knotch on the turbo housing is touching a bolt where the water line for the t25 used to be... ive tryed grinding the knotch on the turbo housing but it doesnt seem to be working...any other suggestions???
Do what i did take the water pipe to machine shop have then cut it and then weld it and grind the area smooth worked perfectly and i was only out of $20 bucks. Heres a pic for you to see
Just clock the compressor side untill it fits. My 60-1 did the same thing untill I clocked it correctly and it fits great.
