pt 50 trim install question
blkTsiWitPsi
Feb 27, 2005
lewiston, Maine
i put in a pt 50 trim and a dejon 3 inch intake now what do i do with the vacum lines that went to the old intake? since the dejon does not have them... second just to make sure when i put in my boost controller i have to plug the wastegate vacum line and go to the other spot on the turbo where the line from the wastegate went with the boost controller line..correct? thanks
I can answer ques 1. on the valve cover you are gonna need a breather fiter,2nd line is your bcs should be disconnected when you installed your mbc, and the 3rd one, i think its the biggest line, is emission, i just put tape over it.
Don't put tape over it, just let it hang.
Its the vent line from your charcoal canister so everyone once and awhile when the ECU decides to vent the fumes they will just go out to the atmosphere.
Your turbo will have a nipple on the compressor outlet.
Run this into your MBC, and then run the MBC out-line into the actuator.
i thought PT turbos came with the actuator already hosed up.
