99gst_racer
Moderator
- 12,009
- 1,696
- Apr 5, 2003
Coloma,
Michigan
Great tech article, BTW.
I have a question about it too.
When comparing these setups:
I would have assumed that the set-up that has the larger amount of vacuum pulling on the crankcase pressure would be the better performing set-up. While doing some searching, I found that most people aren't able to get more than 2-3 inches of vacuum from the pre-turbo intake pipe (of course, that heavily depends on the diameter of the pipe and which turbo is being used).
I really need to measure my crankcase pressure. I assume I have quite a bit even though my engine's tolerances are fresh and tight. Must be something to do with 40+ PSI of boost.
The last time I drove the car, I didn't have the hood on it, and I had a misted my windshield with oil from either the cap or the dipstick.
Also, on the "bigger improved" set-up - is the stock PCV valve still needed with an inline check valve? I assume you have it in the diagram as a back up check valve, right?
The last time I drove the car, I didn't have the hood on it, and I had a misted my windshield with oil from either the cap or the dipstick.Also, on the "bigger improved" set-up - is the stock PCV valve still needed with an inline check valve? I assume you have it in the diagram as a back up check valve, right?
