Problems Making Boost
daysleeper
Aug 25, 2003
norwich, New York
My car has been parked for the winter, and I bolted on IC pipes/BOV/intake during the downtime. Last night I tried to drive it for the first time this year and the idle is fine, and it runs normally until it starts to make boost. At that point the engine RPMs stop climbing and the car hesitates and refuses to accelerate.
I have my MBC connected at the compressor and the wastegate, would it be better to tee off of the vacuum line to the BOV? Would that matter?
My boost gauge reads -15vac at idle, and when the problem starts is just around the time the needle gets to 0 or 1-2 psi.
It wouldn't appear that I have any leaks, there is no smoke from my exhaust, the only sensory indication that there is anything wrong is I can hear the turbo trying to spool but with no results.
I have a datalogger, so if any other information would be handy in the diagnosis of this problem, LMK.
Thanks.
The only way to find boost leak is to perform a REAL pressure test. Here's what I think could be.
1. Boost leaks.
2. Exhaust leak before the o2 housing.
3. Defective actuator.
4. Actuator arm disconnected from wastegate.
5. A almost dead turbo.
Let's rule out #5 because you said you can hear it trying to spool. Rule out #3 and #4 because it would drive like a N/A without the bucking and hesitation. I'm guessing boost leak because
I have yet to see 100% leak free after work done to the intake trac. Good luck.
http://www.vfaq.com/mods/ICtester.html
I built the IC tester yesterday afternoon, and sure enough I was leaking. Fixed now.
Thanks for the response, I'll try and suck a little less from now on. :p
You are welcome. Good job, usually it takes at least 5 posts to convince people to make that tester. :)
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
