Problems after new turbo
george1904
226
Dec 14, 2008
San Diego, California
ok so i just installed my new evo 16G today<br>
everything is connected right and i primed the turbo bt taking the motor fuse of and turnning the car 4 times for about 5 seconds then put the fuse and turned it on. So now there is white smoke coming out between the turbo and the manifold. Is this fine? just something after a new turbo install or is something wrong?
Could be drops of coolant u accidentally got in their, like DSMopar said it could be just grease or other fluids burning off. Ive installed the Evo 3 16G with the extreme psi Install kit about 3 times myself in the past, and no matter how perfect you try to get it, you will always get some messy fluids all over.
Drive it for a couple of days and see if its still smoking. White smoke usually means coolant leak, blue means oil or piston rings. Been a couple years since I have stopped working on these cars, forgive me if Im wrong about the above ^^.
Like everyone else said, take it for a light cruise to burn everything off. When I work on my car now I usually just clean everything after I install it because I get stuff really messy. My car used to always burn for like 5 to 10 minutes after I dicked with it from getting oils and crap rubbed on everything. If it is still smoking after a drive down to the store n back there may be something wrong. I wouldn't worry too much if i were you though.
