problem fuel pump, help!!
john09
Apr 11, 2014
saint amadou, Europe
BIG PROBLEM! I galley
my fuel pump does not put this route has the key, it only works when live!
rvr 4g63 engine, I already looked on the site and I can not find anything that helps me with my problem, fuses ok, ok relay, ect
help me because I do not know what to do, plus it's all over and I have concerns that
thank you
Yea it is a bit hard, are you saying your fuel pump isn't working or isn't priming? If your listening or trying to get the fuel pump to prime by putting it to run it won't unless it sees inputs from cas, so basically you got to crank the cat to look for fuel. That is on a 1g, how do you know it's your fuel pump? Is it cranking and not starting, I had that happen went thru a diagnostic step by step and found out it was my ecu. Yup the famous leaking capacitors got me.
it's on a 2g.
I want to start no response in essence, I have to put the relay to ground to put the pump.
is that it can come from the arbracam position, knowing that the block is right, and originally I had left behind the pulley.
I rvr engine on a 96 eclipse,
knowing that the fuel relay and mfi are separated, and the beams of origin there is only one case
my fuel pump that starts if I put it to ground with the contact.
I wonder if the arbracam sensor can be involved, because it is the origin behind the pulley, and it is to arbracam
