2G Probably a stupid question about crankwalk
Vexiis
Jun 7, 2005
Oceanside, California
Everyone talks about crankwalk and how it will destroy engines.
My question is, if you have the engine inspected for crankwalk and they find it in the beginning (or hopefully you never have it) how expensive is it to repair?
Also, if by some random chance you destroy an engine how much does a normal 7bolt cost on average?
If it has been asked I apologize I have been reading the boards and archives for a while now fairly extensively and haven't found it.
Ah. Bench-wrenching.
Well, if it's just a matter of the end play of the crank being out of spec, it may be as simple as replacing the thrust bearing. Of course, this leaves you with the insecurity of not knowing what caused the play to get excessive in the first place. And such seems to be the world 7-bolters who dwell on CW live in.
I, too, disagree that it "destroys" an engine, but I don't think any of the "causes" of CW are always right. I also think the reason a true cure hasn't been more aggressively sought is that it's not as common a failure as the lip-service makes it sound. Then again, the low-cost and relative ease with which a 6-bolt can be obtained and installed pretty much precludes the utility in effing with the 7.
