2G probably a stupid question about fuel cut
young97 gst
Mar 13, 2014
williamsport, Ohio
but as my uncle said, the only stupid question is the one not asked.
anyhow, by simply putting on 1. the aftermarket air intake for the turbo 2. the aftermarket pipe from the throttle (i dont know what its called) 3. a aftermarket blow off valve and 4. all the number 0 mods. will all this cause fuel cut.
i know dsmlink will fix it or a after market fuel pump. but should i already be experiencing it with just those few little mods?
yeau i thought about that. when that happens or if i have one that would be usually in the rubber hoses or at the clamps? or not?
nah, a cap for the compressor inlet on the turbo and an air fitting on it. Hook up to air compressor and listen for leaks. check the couplers that bend at an angle or rub against anything
