biglady112
- 1,976
- 561
- May 20, 2004
Commerce City,
Colorado
I did some preliminary tuning tonight. I ran out of fuel very fast with the 1150's. And the poor 38mm wastegate is creeping pretty bad. Hopefully when I can figure the fuel out, I can get the boost up, and the wastegate can control the boost a little better.
I did have one pull that based at 25psi and crept to 30. I only streamed that log and had to get out of it as the car was leaning out really bad. Like 13.5:1 before I knew it in third gear. Anything over 21psi in I cannot keep the car from going lean. When you guys see the datalog you will see what I mean. The car is pretty lazy, if you want to call it that, until 24psi. At 25psi it was INSANE. It was probably the most violent car I have ever been in up to this point. Hard to say where the car would have been acceleration wise, but I think 11's are attainable with even the big tranny. The mafraw hit 3500hz in that log. The one I am going to share peaks at 2800hz. The turbo has a serious threshold when it makes that turn to start making good power.
It is truly suprising how well it uses the boost and power. Even with the long gears. I think with the right tranny, some good boost and this car will be a terror in the quarter mile. I am currently looking for a tranny that will fit a dsm clutch.
Oh, and for some reason the 1.6L centerforce clutch is still holding strong. It is just totally wierd.
I was about to begin dialing in the boostest, but ran out of fuel basically at 16psi and just wanted to play a little more before I put the car away for the night. When I take the next step with the fuel system, I will dial the boostest in at that time.
Just thought I would share a fun night.
Steven
ps: put in 4000ft for the props for the boostest. I thought it went in, but did not. In order for my MAP sensor to read correctly, I have to run 4000ft rather than the 6000ft I am.
Steven
Steve I like reading your threads but why not just put all the info in a big thread and call it the HX52 1.6 build.
damn
