Powersteering is too easy and has too much play.
The precision of the steering wheel has to do with the condition of the steering shaft joints, rack and pinion surfaces, rack seals (internal), inner and outer tierod ends, and wheel bearings, and also air in the hydraulic system.
Check the tie-rods, wheel bearing, and the joints in the steering shaft. If these are all good, then rebuild or replace the steering rack.
A smaller p/s pulley would give more power assist. If you want less, you'd need a larger p/s pulley.
A pulley is going to do nothing but wear out the pump faster. The pressure is regulated internally. Air will have nothing to do with precision and slop. If there is air in there it will just make the steering harder. The steering wheel still has a direct link to the rack via pinion, the same as a manual rack, there is just a hydraulic system to detect movement and assist in force. That's why in the technical name there is the word "assist" somewhere :D I suggest making sure the tie rod ends are tight with no slop, there is no excess lash in the rack and pinion, and wheel bearings would cause slop, too. Anything that can pivot on the suspension is liable to cause slop in the steering.
I already checked the tie rod ends. There is no slop in them.how exactly do you check if the wheels bearings are bad? Also, is would upgrading certain bushings to polyurethane in the front help?
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
