Lossing too much fuel need help
99BoostedRS
390
Apr 21, 2009
Queens, New York
So i installed a walbro 255lph hp pump into my n/a 96 eclipse (rest of the fuel system is stock) because at the time i couldn’t afford a fuel pump and i had that one from my old car.
Ok so my problem is im getting really bad gas mileage about 150-200 miles a tank!
When i drive like a grandma (like really slow) i get pretty good gas mileage but once i start to put my foot to the throttle i use ALOT of gas. For example i had 3/4 of a tank and i floored it for about 3-4 blocks and the gauge just shot down to almost 1/2 tank?!?!?
I looked for fuel leaks but did not find leaks anywhere (and yes i looked by the fuel pump hanger followed the lines under the car and nothing)
Im not getting any check engine lights either
Does anybody know what can be going on?
You might be burning too much gas cause your car is running rich. Check your exhaust area/tip to see if it is covered in black residue which is a typical sign of your car running to rich in fuel.
There can be tons of reasons why a car can start to get horrible gas mileage. Try the easy less expensive fixes first like doing your own tune-up to see if that helps. Bad 02 sensors can also cause you to get horrible gas mileage but at 80 bucks a pop you don't want to change them unless you definitely know that you need to.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
