power transistor connector test?
bcowx06
74
Oct 20, 2009
akron, Ohio
Im trying to figure out why my talon is only sparking on 2 plugs, i checked the CAS and Transistor but still nothing does anyone no what pins in the connector should be getting power and what not i didnt see any bad wires just wanna make sure:hellyeah:
I had the same thing happen. My transistor plug was covered in oil and
corrosion. I gave it a super good cleaning job and it fixed everything. Try wiggling the connector while the car is running, that is how I diagnosed mine. While wiggling, all the cylinders would drop out, or all of them would work, or only two would work, depending on the pressure applied.
Sorry I can't help you out with testing the connector
