dwdsm
- 595
- 45
- Apr 28, 2005
Scenery Hill,
Pennsylvania
Well, I have a unique issue that I just need to bounce off a few of you. I just got finished with my wire tuck and relay box relocation. So obviously I did alot of trimming and lengthing. I switched to dsmlink v3 and loaded my v2.5 map and what wouldn't load I copied to the new version. The car Idles perfectly and drives smoothly until under boost 10-18psi. At no specific rpm or boost range the car will break up and adding fuel doesn't change anything. Then after driving for a while the car will show a misfire on cyclinder 3 and run on 3 cyclinders. My wideband goes to 19:1, all at the same event. 1,2,4 showed that they truly were running super lean and cyc 3 was pig rich. The wierd part is the last time I took it out after changing my wideband sensor it repeated the same process but I noticed if I just shut the car down and started it right back up it was fine. So I think something electrical is "loading up". Is this possible? Another question I have is the ground to the resistor pack through it's frame that bolts to the firewall? The mitsu book doesn't indicate this. I just painted it and could easily have a bad ground there if that's the case. Any thoughts on where to start would be helpful. Tomorrow I'm going to switch my injectors around to make sure it's not one of them.
Thanks,
Dave
Thanks,
Dave
