Plx m-300 ?
For the wideband, this is the sensor you are looking for:
Go to a Volkswagen dealership and ask for a o2 sensor off any 1.8t engine. So just say a 2001 Jetta 1.8t. They will bring out the exact same sensor you have in your car.
It's the VW 7057 sensor, the exact part number is on the sensor itself, you will see VW and a list of numbers with the end numbers being 7057.
or you can just go here:
https://www.1stvwparts.com/partscat.html
part number is: 021-906-262-B
Its a Volkswagen part number.
This was taken from a random Honda site after doing a quick Google search...
If it's just the narrowband sensor you are replacing, just order the front o2 sensor for the vehicle as it plugs into your stock engine harness.
Are you replacing a stock o2 or a wideband? If It's a wideband o2 u have to replace it with a wideband o2. A regular one won't work
Apparently through there, try searching elsewhere. There isn't just 1pkace that sells the sensor. See what PLX sells them for.
