Please Help1 tranny trouble after engine swap
krickit90
Aug 12, 2005
Denton, North Carolina
Please Help
I just had an engine swap in sons 1993 eagle talon. Prior to the engine swap transmission was ok. It changed hard at times but no other problems. On the way home from the shop car gets stuck in low gear. Any suggestions
sounds like its entering limp mode (what the tranny goes into under a fault in the tranny). id check all electrical sensors and wiring and go from there. if not that, have the tcu checked or have the fault codes extracted from the tcu and see what the problem is.
:dsm:
