Engine Swap = Tranny swap?
Manderfall
Apr 22, 2008
Lisbon, Connecticut
I Recently spun a baring and punched a hole in a valve in my 420A engine doing something stupid and not checking everything first. I have raised some money and i am going to put a 4G63 engine in to replace the 420A. I was wondering if the transmission would have to also be replaced.
The transmission is an after-market transmission and is not a regular eclipse manual transmission because my car had a manual overhaul done on it.
1996 mitsu eclipse gs non turbo.
Thank you for your feedback
-David
I don't believe the stock 420a transmission will work. The 420a transmission bell housing is smaller than the 4g63 transmission so the flywheel and clutch will not fit. However I don't know about your aftermarket transmission but it should be at least the same size bell housing as the stock 420a transmission and only internal work done on it.
yes i have done some research on it and it does seem way too costly to swap... i think im just going to get a 420A engine from a junk yard and rebuild it if necessary to get it working again. But this time i am going to make sure everything is 100% before i try going 140mph again.
That sounds like a better plan to me, money wise and the amount of work that would go into a 4g63 swap. I recently rebuilt my 420a, I'm thinking of adding a turbo kit to it but anyways my advice would be either turbo the 420a or save up for awd dsm.
