Please Help!! No start
bobbafet7
Dec 13, 2005
Newburgh, New York
Yesterday I had just finished swaping out my cracked 1g exhaust manifold, 14b inducer housing, and swaped out my cracking dampener pully. Apon finishing I cannot get the car to start. It only cranks and occasionally sputters like it wants to but doesn't. It is a full 1g jdm engine swap to begin with in a 95 talon. Now I assume from what I read that the firing order is the same as stock 1g <4-1-3-2> since it has a 1g head and block <I mixed up the plug wires when I removed them to change the valve cover gasket>. Also the engine just seems to flood out. The spark plugs get covered in gasoline. Any help to get my baby back on the road would be greatly appreciated
I checked that it was a little loose I snapped it in all the way, but still no change at all.
Yeah I am getting plenty of spark. I think that when I removed the crank pully I may have spun the engine backwards and skipped the timing belt 1 or 2 teeth off. I hope that if I did that I didnt bend anything trying to start it. Each time i turn the crank pully around it lines up differently with the mark. I'll take off the covers and check all the marks tuesday night
