please help me!
BichoteAWD
40
Oct 28, 2010
Boosted, Florida
I have a 1g 6bolt awd talon.Motor was just rebuilt everything new. im running Crower stage 2(272) cams on intake and exhaust. I have adjustable cam gears. The machine shop set the timing and degreed my motor. For perfect valve opening and closing. the head and block had to be shaven so i was guessing it had to be done to compensate. well now everything is back together and running. Im using dsmlink i set my values for injectors and everything but the airflowperrev stays above .40. I was told it needs to be around .25. could degreeing the cams cause this? should i set the cam gears back to zero? Car runs decent. just having problems with idle. Please help me out asap. thank you
