turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Well, since i foudn i popped a HG tonight (oil in water and water in oil) i'm going through putting new ACL bearings inthe rods and mains as well as putting in h11 studs and some sort of HG
here's the thing, I don't have time to have the block surfaced or the head(the head was done recently anyway and was rebuilt completely)
Anyway.. I have a JOB now for thank god (untill their insurance finds i'm labeled disabled i'msure) but anyway i need to be there monday and wanna overnight from MAP or anyone who will do so
problem is i can't pick a head gasket. with the h1's i want to run up to 35-37psi TOPS and was hoping to maybe get away with a Fail-pro again or get the cometic since it has a coating on it and is only 88 bucks
do you giuys think i can get away with the cometic or should i go composite and limit the boost to something reasonable (suggestions welcome)
PLEASE I NEED HELP BY MORNING!!
(edit: i'm broke buthave some credit on a purchase i didn't get so i can spend at some stores through paypal) if i go local i will buy a friends un-used h11's and geta fail prob but that leaves no bearings
DO you guys think mainand rod bearings are vital when there's water been in the oil (i kinda do)
. I wanted to see a pic of the gasket to see if there were any holes burned in it, but Glenn's isnt messed up where that usually happens, so it must be the block or maybe the stud was "floating" on that side because there was a bit of junk in the bolt hole when it was put in originally and the stud wasnt able to bottom out fully in the hole
now i just need a vacum can once i get the freaking head on
if it blows again, into the river i drive it if it hasn't sold by then
