Piston help
They don't look like the NPR pistons we have on our shelf. I'm not sure what that funky circular thing is on the top center of each one.
those look about right. i had some npr pistons for my 7 bolt that looked like that. i have 4g64 npr pistons now which aren't coated and they also have the circle on the top
OK, I found ITM pistons on Rock auto for 35$/ piston
or they have DNJ for 75/set
Which one would you guys recommend.
I heard they are both similar in quality to the NPRs
Of the two of em, I'd go with the ITM, they are re-boxed npr, I'm uncertain if the dnj are re-boxed as well, or if they are made in a dnj owned foundry.
TIP: if your a 2g you could always go with the evo 9 pistons, I'm sure someone has an oem set from an evo build that are still in good shape.
HI there, I got the same set of pistons and ring for my stock 7bolt rebuild on my 95awd eagle talon making 440hp 480tq on 25psi with the new fp black htz turbo for the past year with no problem at all
