pic's of your 420a turbo setup
Awesome thread guys I got rid of my 420-T years ago, but this is making me want to mess with my Talon now hahah.
How many of you had to remove your internal safety bumper to install the I/C...? I'm looking for an I/C solution but want to keep the bumper intact. I was thinking the 7 or 8" tall ones found on ebay would work well running below the safety bumper, but I don't see anyone installing them...
Lovin the manifold but why that extra tube for eth dump it kinda kills the whole look?? Hot setup though. I have aquired about getting a manifold made that will make for a crazy setup. hoping to add pics to this thread in the near future.
i had to extend it, to clear the turbo housing, i was originally expecting to mod this manifold anyway, and by the way i will polish that tube to it matches as much as possible. Not final product as seen! :talon:
This is before my engine blew up. Trying to decide what route I want to go now.
Here is my setup. Hahn stage I with custom side mount setup.
Blew the motor but I have a 2.2 stroker block on order from howell automotive. Just waiting for it now. Also have a new front mount setup I just installed yesterday.
This is what it looks like as of right before the fmic install.
Thought I'd share my plate too.
Most or not all of us have removed our safety bumper to install the IC. I removed mine, but I've got a pretty large IC (And still working on installing my whole kit). You can go ahead and try it out and tell us how that goes. Although I don't know how that would look. If it's pretty lookin' or whatever. :dsm:
Sorry I didnt have time to wash the car or bolt on my wheels. I roll around on stockers because they ride well. Heck they are new tires might as well use them on the rainy days.
This is a Turbonetics 60 t3/t4 turbo. I am running a 7.25 psi spring when I am riding around town. The Wastegate ia 38mm Tial. I have a new Intake manifold and couplers to install as well as some powdercoating. The BOV is HKS and I purchased it off ebay. I had all the tubing bent at Maxi muffler and worked out well. I only have three couplers because everything else is welded. I will upgrade injectors with the Candy Red intake manifold this week. When I do I will probably run 9 psi boost. The fuel system was all purchased from Hahn. 255L fuel pump and all lines. I actually want some longer lines that do not need to cross over the valve cover but thats what I have for right now. Progress is fast but I have not had time to drive out to a Dyno to get some number yet. I have been very lucky with the whole occurance coming accross deals. Right now I need to fix a Boost / vacuum leak I believe is from a blown out gasket on the intake manifold.
Codename: Upgrade, Xbox 360 Talon
More powder coating to come on the thermostat, piping, intake manifold, turbo heat shield, and throttle body.
I have a Black APEXI SAFC 2 for sale. It will not work in conjunction with a Hahn port fueler so there is not much reason to use it. I will sell it for $80 My loss your gain. 423-316-7926
This is what the car looked like about 2 months ago
This is the pic right after the install. I was still excited. I replaced the air filter with onse that has a heat shield , and I need to have the exhaust coated black as its starting to rust just a little.
New setup COMPLETED!
garrett gt3076r, v band DP, anaconda sex ss lines, new 5 bolt cam gears after my horrific incident with the pos AEM ones, fresh paint in the engine bay and stock wiring harness and ecu are GONE! Ive got mike building an intake and exhaust manifold for me and some Omnipower coilovers on the way! The car will hit the dyno after I get the manifolds
I mounted my intercooler right up under the bumper support. I trimmed the bumper cover to fit.
garrett gt3076r, v band DP, anaconda sex ss lines, new 5 bolt cam gears after my horrific incident with the pos AEM ones, fresh paint in the engine bay and stock wiring harness and ecu are GONE! Ive got mike building an intake and exhaust manifold for me and some Omnipower coilovers on the way! The car will hit the dyno after I get the manifolds[/QUOTE]
Wow I like your headlights. Where did you get them. They come out to a point like the 95 lights and 97-99 talon. I am looking for a set like that. WHat brand are they or did you buy them off a 95 and paint them?
Wow I like your headlights. Where did you get them. They come out to a point like the 95 lights and 97-99 talon. I am looking for a set like that. WHat brand are they or did you buy them off a 95 and paint them?[/QUOTE]
they are factory 97 talon headlights w/ painted bezels, Tsx projector retrofit, lexus hid's and I removed the yellow plastic over the side markers:thumb:
Very very nice! Do you have any dyno numbers?
Here's a couple more of mine. Although I posted a couple others in post 156, these are a little different and what the hell, the more the merrier ;)
I've got several other pictures of the car in my photography thread in the hangout, check them out.
