Drewpy Dawg
- 277
- 313
- May 18, 2008
Sachse,
Texas
For those who have replaced the seal in their cyclone manifold: when you put it back together and re-installed the little throttle plate screws did you peen the back side to keep them from backing out? If so, how? I can't see any easy way to do it. Did you just use loctite? Thanks.
, but if locktite is holding my converter bolts from loosening up and my crank sprocket up front, if it were mine, I'd use the glue and let it set up for a few days. It doesn't see that much heat, but I'd use Orange Jell Locktite, if not Red. Orange you can break free without heat but heat makes it soft quick and easy, if you have to take it apart ever again.
