renovatdkitchen
- 622
- 38
- Sep 25, 2011
Toronto,
ON, Canada
Hi,
This is my first build I'm doing and just wanted to ask if I have everything needed to assemble the engine (not including oil pump, machine work required and other supporting mods, but just so I can finally torque the head studs back on). Mainly just don't want to make another trip to the store as I'm driving down to the states for the parts.
Wiesco pistons (come with rings and pins)
Eagle rods (come with bearings an ARP bolts)
ARP head studs
Head gasket
Valves
Valve springs and retainers
Valve locks
Valve guides
Valve seals
Thank you!
ARP head studs
Head gasket
Valves
Valve locks
Valve guides
Valve seals
Thank you!
And if you removed the oil jets get new washers for them.
