Part numbers for camshaft swap
RadDsm
1,679
24
Apr 28, 2008
Eugene, Oregon
I'm going to be swapping out my 272s in favor of a stock set of camshafts. I'm going to order the parts I need, but I want to make sure I get everything. This is what I have so far, is this everything? Or is there a tool made to make it easier?
Cam seals MD133317
Valve cover gasket MD125939
Spark plug hole gaskets 4x MD125940
Half moon gasket MD050536
Cam tensioner tool MD998738
Anything else I need?
I dont see a need for the cam tensioner tool unless it is referring to the piece that is going in from the rear to apply pressure to the timing belt tensioner arm. I would add assembly lube to the list as you dont want them ran with out lubrication initially
