part dinosaur.com
I bought rings and gaskets off them.They seem to be doing pretty well so far.I was pretty satisfied with what I got.
I purchased my entire timing set, water pump, and misc. gaskets through them.
I plan on doing it again when the time comes. The products that I have recieved from them have been of great quality.
yes i bought alot of items from him for my geo metro. i wouldn't say the quality of his items are the best, ie. don't trust your headgasket to this brand that he uses, but for everything else it's fine and besides that he is a stand up guy and will do anything to make you happy.
I've bought several full engine gasket sets from this guy (including the valve stem seals) and everything has worked beautifully. Bid in confidence, that old dude is the shizzle! =)
I've bought several gaskets/sets from him, as well as a set of timign components and a water pump for my 01 diamante.
quick shipper, great prices,
and honestly
solid customer service.
:thumb: :thumb:
I would not worry about running the ITM pistons from him. I have had mine for about 6 yrs with no problems. The itm hg also worked well for me when I was running a b16g@20psi. I only replaced it because I had my head off for cams, springs, and retainers. That was a long time ago but I still order all my gakets and seals from Bruce ( www.partsdinosaur.com )
The itm oil pump I purchase in 2000 is also still on my car and has worked as flawlessly as a mitsu part would.
I just got done putting my car together using his Upper Gasket Kit, and all timing parts (belts, tensionsers, adjuster, etc.)
The only thing I didn't use was the Head Gasket that I received as I went with a MLS one.
Everything about it is great, he even included instructions on doing the entire timing belt procedure from beginning to end. That old guy is awesome!:thumb:
