Paint on front mount??
93_GEE_ES_EX
138
Dec 23, 2002
Orlando, Florida
I recently purchased a FMIC spray painted black with the guy's intials.I want to remove the paint, is there a way to remove the paint?
Try lacquer thinner; that'll remove most paints. If that doesn't work for you, there is also a graffiti remover solvent sold at most home improvement stores that is specially formulated for spray paints.
I wouldn't sand something as delicate as a FMIC.
I 2nd thinner. Should do the trick.
Or carb cleaner :) Not sure what's worse for the environment but thinner can be reused.
The thinner or the brake cleaner as described above, carb cleaner dosent work as good as brake cleaner, but they all should take it off with no problem.
1g2fast said:
Had a friend with a similar problem he used thinner and he had no problems
Aircraft Paint Stripper from autozone or some other auto place.
It takes all paint off within like 3 minutes. No hassle.
dont get it near anything that you want to keep paint on though =)
Haha. Who does that to their front mount? It's like in elementary school where you'd scribe in your initials on your calculator...LOL
He said initials...i doubt its dejon. Im glad i got my dejon before they started painting the "dejon" on them.
