P0420 CEL code
gsx 1
Oct 31, 2010
big bear, California
I was wondering if anyone had some advice on a cel code p0420. My check engine light has been on for some time now and when i checked thats what i got. I still have my stock cat on so im just curious if anyone has any help on whether this could b just a simple sensor problem or will i have to replace my cat as well?
If your lucky it's an O2 sensor I replaced both my O2 sensors first and that didn't work so I replaced my stock cat and cat-back system and it still came back on after a while then I replaced the stock O2 housing along with the downpipe and it came back on so I replaced the exhaust manifold and it hasn't come back on but I did find the exhaust leak it was the gasket that is between the turbo and manifold that I replaced recently when I replaced my turbo so now it's all good.
Watch the front and rear 02's on a scan tool. If they both are reading close to the same then its time for a cat.
What your looking for is when the front 02 changes the rear will tend to follow. On a healthy cat the front 02 should dither rapidly while the rear 02 will more less stay constant to an extent.
sent from my evo.
