dgdsm
- 177
- 4
- Aug 24, 2008
Tarzana,
California
I revved up the engine a couple of days ago in neutral to 5K+ after an extended idle for just a few secs, and since then I've been having a rough idle problem. It eventually throws P0302 (cylinder #2 misfire) at idle and the STFT goes up to +24. Before this the fuel trim was a little high (LTFT+STFT = +12) at idle, but at this point STFT+LTFT is +36 . It goes down to normal levels when driving in gear, or if I rev up the RPMs in neutral. The numbers from the O2 sensors also go haywire at idle, like the cat isn't doing anything, but look normal while moving in gear.
Is vacuum leak around cylinder #2 the only way to interpret this? I don't see how revving the engine up momentarily to 5K+ can rupture an intake manifold gasket. Would an exhaust manifold leak explain the high idle STFTs? Or is this +24 number just the effect of the ECU dumping fuel into cylinder #2 because it's not firing? The compression numbers are 160-135-170-160, so low compression in #2 could be a part of it but it doesn't seem to explain everything.
