Raider_831
- 32
- 8
- Mar 2, 2024
Greenfield,
California
Hello I have a stock 1999 Mitsubishi Eclipse RS with the 420a engine. It currently has 195,500 miles. I’m currently dealing with a rough idle and check engine lights p0304, p0303, and p0302. None have came on at the same exact same time since I’ll try and fix something and I reset the codes but they eventually return.
I changed the spark plug wires and spark plugs at 178,400 miles with the NGK wires and NGK G-power platinums spark plugs last year in July.
The first code I got was p0303 back in November last year. My mechanic recommended to switch the wires and spark plugs around. I even bought a new spark plug to replace the potential bad one that was in cylinder 3. That seemed to take care of the code for months.
Then last month October 3 the p0303 (for the 2nd time) came on flashing with a rough idle, but it went away by itself and I reset the codes the car seemed to be good again. Then this month November 11 p0304 popped up for the first time with the rough idle but seemed worse.
I drove the car back home, but then my first fix was doing the coil pack and reset the code. Drove the car around town and freeway for a couple minutes but as soon as I made it to town and made a stop I could feel the rough idle at the stop. I came home and told my mechanic to check it out.
Then yesterday when I was going to drive over to my mechanic when I turned the car on the check engine light came on this time p0302 for the first time.
He did the smoke test, his main finding there was the EGR valve potentially smoking a little more than normal, my new oil cap was also smoking. He did the timing belt check he said everything looked good no jumped teeth or damage.
He then finally checked my spark plugs he said they did look like they could be a problem which we bought and replaced, but today the car still seems rough on idle.
He told me to drive it around and see if the check engine light returns. I did buy the fuel injector test kit but he said the injectors looked a little complicated but that we could do it if the light returns.
The mechanics main concern was the code jumping between cylinders and not isolated. Does anyone have any experience with this or have an suggestions on what to do next?
I was dealing with the p0420 code last year as well. Which I took care of this year and replaced the cat and that took care of the smog I passed easily back around May this year.
Thanks in advance
Thanks in advance
