p0105 map sensor check engine light problem
sillyme
151
Aug 3, 2005
seattle, Washington
i ran the code it's throwing manifold absolute pressure code. i have the maf translator with a gm mass air flow sensor. the car runs good with no hiccups but i cant get this trouble code off the ecu. is the wiring wrong or is this normal? thanks
a maf sensor and a map sensor are 2 different things...did you remove the map sensor or is it busted, maybe you mounted it with a vacc line? is it leaking? LOL need more info i think.
-----bump-----
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
