Check Engine Light Problem
Cgillies86
59
Dec 22, 2004
Rochester Hills, Michigan
My check engine light is never on when I am driving ,however, when I come to a complete stop while in nuetral the check engine light comes on. But if I push in the clutch the light goes away. Other times if I just tap the gas it will go away. It is kinda weird but I would like to know if anyone else has had poblems like this. I have a fidanza flywheel, I don't know if that is causing it?
Yes, check the CEL codes.
My battery terminal was loose one time, it had starting problems. tightened up the battery cable. problem went away.
Check the ECU Error codes, and also check the connections on your injectors/coil pack/PTM. If one of them is shaking an getting an intermittent connection you'll get a cylinder misfire code. The flywheel isn't causing the CEL, and a weak battery connection isn't causing it either.
I connected my logger and it said my throttle point sensor was bad, anyone know if this could be it?
So if one of the injector clips was broken off one side, it could cause it to throw a code because of vibration?
He was trying to help you troubleshoot it BEFORE you datalogged it and found out what the problem is.
It's the TPS! :coy:
You could find one at dsmtrader.com Be careful whenb buying online. Only use paypal, and buy only from people that are verified members, and that use a paid email address like AOL, Comcast, etc.. Watch out for people that can't spell, type in all caps, and use Free Email (Yahoo, Hotmail)!
There is an FAQ or 2 on it, including testing and replacement. Please search here and google to locate.
http://www.plymouthlaser.com/tps.htm
Good luck friend. :thumb:
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
