P0105 CEL
dennis-1009
65
Sep 7, 2009
Loch Sheldrake, New York
I have read numerous threads on this CEL and none are any help. I am getting this CEL and I have tested the map sensor and was getting the correct reading. I put the vacuum pump on the sensor and those readings were correct as well. Any ideas as to what may be causing my car to stall and this CEL? The car runs for a while and then it stalls, if I try to drive forward or in reverse the car stalls as well. Once the car stalls it is hard to get it to stay running and then when it does, it stalls again when it runs for a while.
P0105 is the baro ckt.
Unplug the MAF connector and check for pushed/bent pins inside the connector, also check for frayed/cut/broken wiring going into the back of the plug. If everything looks like it should plug it back in and make sure it seats securely into the MAF.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
