CEL P0105 and engine problems
dennis-1009
65
Sep 7, 2009
Loch Sheldrake, New York
I have a 1998 eagle talon and I was getting the P0105 code and I did the vaccuum lines and I put in an AEM fuel pump. The car will run for a while and then stall and it stalls when you put the car in gear. There is a strong fuel smell and now the car won't start. Any suggestions as far as what I should check next.
Check to see if your MAF is operating properly. Also, if you're ruining an unrecirculated bov, and have the oem MAF, that'll cause a major problem. Would also check fuel filter for the fuel problem.
Would a bad fuel filter also throw a code p0170 (fuel trim bank 1) *02 already replaced,injectors cleaned and new seals
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
