2G Overheating?
97GSTbuilder
Feb 9, 2015
Wasco, California
Im having a overheating problem with my car, it has brandnew hoses, theres no pitched hoses, its a rebuildi engine with a brand new head gasket too, thermostat is engaing. After the car has been running for 10 min it starts to over heat.
Some possible questions that you have not addressed:
  • Is the system properly bled of air?
  • How new is the radiator cap?
  • Are all of your sensors plugged in?
  • Are your fans turning on?
  • Have you completed a compression test?
  • Pressure test the cooling system?
  • Belt for water pump properly tensioned?
What temp are you calling overheating?
Factory cluster gauge or aftermarket gauge?
